configure ports dot1p
configure ports [port_list | all] dot1p dot1p_priority
Description
This command configures the default dot1p priority to be used for the internal priority for untagged traffic on the specified port.
Syntax Description
port_list Specifies a port list.
all Specifies all ports.
dot1p_priority Priority number from 0 to 7 to be used for untagged packets.
Default
0.
Usage Guidelines
Use this command to configure the default dot1p priority to be used for the internal priority for untagged traffic on the specified port. This priority is used for untagged frames when dot1p examination is enabled on a port.
This command was first available in ExtremeXOS 16.1.
Platform Availability
